Linetype Appearance not showing properly
Message 1 of 10
I just copy some linetypes to a new drawing that Im working on it but the fonts are one on top of the others.
Replies (9)
Message 2 of 10
imadHabash
we need more details ... would you please attache a drawing sample with that line-type for testing ? also you may need to check your Annotation scale .
Imad Habash
Message 3 of 10
MikeKovacik4928
The linetype hasn't been created properly.
you will probably find the linetype definition is wrong.
Look in your acadiso.lin file probably located somewhere like
you will probably something like
*SANITARY_LINE2,SEWER line ---SAN---SAN---SAN---SAN
A,12.7,-5.08,["SAN",STANDARD,S=10.54,U=0.0,X=-10.54,Y=-1.27],-6.35
which would give a line looking like yours
instead of something like
*SANITARY_LINE,SEWER line ---SAN---SAN---SAN---SAN
A,12.7,-5.08,["SAN",STANDARD,S=2.54,U=0.0,X=-2.54,Y=-1.27],-6.35
which would give a line without the letters interfering with each other
I have attached a course booklet I wrote in 2007, which explains how linetypes are created
look at page 23 which explains how to set up the text correctly.
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman/trainer
Inventor Pro 2018; Autocad 2018
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
Message 4 of 10
Attached you can find the dwg
Message 5 of 10
Thanks for all the information, is very useful.
But Im using the same lines in other drawings and looks perfect.  So I don't understand why not in the one in question.
Message 6 of 10
user181
Hi @Anonymous   The linetype definition is using the text style "Standard". Check the height assigned to the standard style with the _style command in the drawing that looks correct and then set that height to the standard style in the drawing it appears incorrect and then regen the drawing.
Message 7 of 10
s.borello
Have you checked the LTS of your project and the line in question?  Looks like your dwg has a LTS of 20 and your specific line has a LTS of 10.  Do these match the settings from your other dwg where these line types display correctly?
Message 8 of 10
Alfred.NESWADBA
your linetype seems to use text-style "STANDARD", this text-style is set to a text-height <> 0, but for usage in linetypes you need to leave this at 0.
So start command _STYLE, select "STANDARD" on the left side and change it's height to 0
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 9 of 10
Thank you so much, something simple but I missed it!!
Message 10 of 10
MikeKovacik4928
Never saw that one!
Thanks Alfred, I think I will update my course notes to from 2006 to 2018 as well as adding
in that note about keeping text height on 0 for linetypes, I was totally unaware of that!!
Mike
