Linestyle double lines parallel - AutoCAD
srleone
srleone
I also need a double line linetype that I can share within a .lin file. I want to draw a single line, but have it appear as two parallel lines.
@srleone This post has been moved to a new thread for this question and the title modified - CGBenner
Kent1Cooper
@srleone wrote:
.... a double line linetype that I can share within a .lin file. ... draw a single line, but have it appear as two parallel lines.
The only way I can think of to do that is with a linetype involving a Shape or a Text character.  Here's an = sign in the TXT.shx font (above), and a series of them, slightly overlapping (below), that could be accomplished in a linetype definition:
But curves would be kinky:
And things like changes in direction in Polylines would not look as I expect you would want them to:
A Multiline Style would overcome the latter, but [as pointed out already] curves would be out of the question, unless drawn kinky in segments [but the segment joints would at least be cleaner than the above].
Kent Cooper, AIA
CGBenner
@srleone
Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
shanushri
Community Visitor
Community Visitor
XXD COMMAND DOSENT WORK
