lines with arrow
lines with arrow
Message 1 of 17
lines with arrow
hello everyone,
I wonder... it's possible to create a linetype that ended by arrow? (like in P&ID drawing).
thanks!
Replies (16)
Message 2 of 17
m_kingdon
What is the purpose of the arrow? You are probably better off staying with Leaders and Dimensions.
Mike Kingdon
Civil 3D Zealot
Message 3 of 17
Hi David, the simple answer is no, you can't. I asked the exact same question and got the exact same response you just did.
I really want to symbolise a certain type of line with a symbol at the end but will have to use dimensions to do that. I tried creating a block but could not insert it where I wanted it at the right angle, scaled correctly. I have not bothered to try dimension lines because all my lines are now created by other software and imported to ACAD so only a line style would help. Let me know if it works for you.
Message 4 of 17
Kent1Cooper
I agree that a Leader is the way to go, and you can define a separate Dimension Style to use for these, if you want them to be different from your other Leaders and Dimensions.
A linetype won't work because it will need to have a definition cycle with a certain length, and any Line/Polyline/etc. longer than that length will have more than one arrowhead, and even if the length allows only one, except when the length is exactly right, the arrowhead will not be at the end, but there will be some line portion beyond the tip of the arrowhead.
But you may find this usable -- not a linetype but an add-an-arrowhead routine.
Kent Cooper, AIA
Message 5 of 17
hi eventubbergh,
I'm afraid you're right Smiley Sad . if you use the Autocad P&ID you haven't problem, but with AutoCad "naked" is not possible.
Let me know if in the future you'll find some solutions. I'll do the same.
have a grat day!
Message 6 of 17
Linetype may have been the wrong terminology but the idea is still the same; we want line endings like just about every other piece of software that I have even used that can draw lines. It's crazy that we can't!
Thanks for thre link, I can't open it though. I will try again later. I still think that a general style for a layer for line endings would really work. If I need to individually select every line to change it every time I import the lines I will be here for days each time.
What is Autocad P&ID?
Message 7 of 17
Kent1Cooper
@Anonymous wrote:
.... we want line endings like just about every other piece of software that I have even used that can draw lines. It's crazy that we can't!
I haven't used other software that does line endings in that way.  [That is, other than the optional shapes of the ends of things with pen width in Plotting -- rounded, squared, etc. -- but those don't include anything like arrowheads.]  But what you describe as a Layer setting sounds like it would do the same to both ends of all Lines [and may I presume also Arcs, open Polylines, etc.?].  That certainly is not in accord with your image.  Even if such a thing could be made to put a special end on only one end of each object, that might be workable as you're drawing them with a Layer like that current [e.g. if it uses them at only the beginning of each Line -- that's essentially what a Leader does].  But if you're importing something made up of ordinary Lines that you would want to put on such a Layer, you wouldn't have control over in which direction they were drawn.  Wouldn't you still need to go through and check each one for whether the arrowhead is on the end you want, and reverse a lot of them?
[The Cadalyst website generally, not just that linked sub-page, seems to be having a problem at the moment.  So do try again, but even if it's somewhat viable for you, it's still going to require going around and picking ends of things you want arrowheads added to.]
Kent Cooper, AIA
Message 8 of 17
nestly2
Piping & Instrumentation Diagram
There is a version of AutoCAD that's customized with tools, routines, and symbols to automate creation of these type of drawings.
About 3 minutes into this video automatic flow direction arrow heads are demonstrated.
Message 9 of 17
hi,
I use Autocad Electrical which has inside some library of P&ID symbols, but for drawing chemical plants the better is AutoCad P&ID.
Using Autocad Electrical I draw a normal line hence add a single arrow (is a basic simbol) according direction.
bye bye to everyone.
Message 10 of 17
steve216586
I created an arrow through dynamic block. When I insert it, I have a rotation parameter to align it with my line and to the direction of flow. Hasn't let me down yet.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
Message 11 of 17
GrantsPirate
This is very rudimentary but it can be done through a simple lisp routine.  It could be done much nicer but this is about the extent of my knowledge of lisp.
(defun C:PLR (/) ;draw Pline Left to Right with arrow at the right
 (command "pline" pause "w" "0" "0" pause "w" "0" "0.075" "@0.125<180" "w" "0" "0" "" ""))
(defun C:PLD (/) ;draw PLine Down with arrow at second pick
 (command "pline" pause "w" "0" "0" pause "w" "0" "0.075" "@0.125<90" "w" "0" "0" "" ""))
(defun C:PLU (/) ;draw PLine Up with arrow at second pick
 (command "pline" pause "w" "0" "0" pause "w" "0" "0.075" "@0.125<270" "w" "0" "0" "" ""))
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 12 of 17
wow!!!
that's great! As soon as possible I'll try it (next week I'll in vacation... Smiley Happy).
bye
Message 13 of 17
Steve, could you share that or tell me how? The rotation in AutoCAD frustrates me now end and I can never get it right!
Message 14 of 17
Sofia.Xanthopoulou
Hello @Anonymous,
that was a long vacation Smiley Happy You never came back to tell us which way to go here. Was it the dynamic Block or the lisp routine or another way?
Please share your experience with the readers of this forum - I am sure they will be thankful.
Thank you
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Message 15 of 17
hello to everyone,
I'm came back from vacancy and from .... hard work days!
It seems there is not solution for the question about the arrow. I've tried LISP routine, but none results.
the only solution is to use AutoCad P&ID, on the other hand this is the application fit for porpouse... Smiley Wink.
it's all for now, bye
Davide
Message 16 of 17
Sofia.Xanthopoulou
Agreed, @Anonymous,
use the right tool for the job Smiley Happy As you said P&ID.
But maybe you will find this kind of handy. And if I am not mistaken, this is what @GrantsPirate tried to accomplish with his lisp routine.
Regards
Message 17 of 17
what Sofia suggests is the "basic" function of AutoCAD when we use Polyline. My question is different: select a different linetype wich enables us to ended the line by the arrow.
I've tried also  the LISP routine but it seems doesn't run...
My opinion is that the best solution is to put the "arrow  block" at the end of each line... or to use the right tool for the job: Acad P&ID.
bye
Davide.
