Cannot explode ellipse
Message 1 of 11
Another day, another problem.  This morning I tried to paste the text CHOKER, to the outside of the cylinder that is the primaary structure of the Choker device.  The letters are a solid created as previously explained above.
I brought the text in using the Insert command, exploded it and then maneuvered it on to the surface of the cylinder. Then pushed it into the surface a few thosands and tried to Union the two items.
That did not work right off so I exploded the text one more time and got this frightening message "Cannot explode ellipse"   Who would have thought that such a thing would pop up.  The letter O in the text is an ellipse.  BUMMER!!
So now I have to go all the way back to the creation of the solid letters and try to find a font that does not use ellipses for the letter O just because Autodesk programmers can't explode a solid elllipse. The font used, CORBEL, closely matches the original part and my customer expects the replacement part to look like the damaged part.  Silly man!   See the attached cartoon for more information.
Edited by
Discussion_Admin
Replies (10)
Message 2 of 11
The screenshot in my last post did not work so here is a PDF of the part.
Message 3 of 11
TheCADnoob
you are going to have to draw an elipse (the old way). and replace it
Type PELIPSE and set that to 1
draw your elipse ELIPSE
remove the regular elipse by deleting it.
select you new elispe and then EXPLODE
CADnoob
Message 4 of 11
jackshield
"The letters are a solid created as previously explained above."
DID I MISS SOMETHING?
Message 5 of 11
darawork
Autocad will reduce solids to 2D surfaces when exploded, the fact that it reduced the center of the letter 'O' to an ellispe may be impressive from a programming point of view... and very helpful in creating additional, different, extrusions along seperate paths. With reduced polygons as a bonus.
I find the best way to extrude text in autocad to be via MS Word WordArt outlined text. Copy in Word, paste 'As Autocad Entities...' in AutoCad.
Good conversion of text, without it creating ellipses. Work in a big scale, then scale down in AutoCad.
For anything more complex, e.g shapes or logos from Bitmap.... I use these steps;
https://forums.autodesk.com/t5/autocad-2013-2014-2015-2016/cad-blocks/m-p/3799659#M13263
Darawork
AutoDesk User
Windows 11, 3DS Max 2026, Revit 2026, AutoCad 2026, Dell Precision 7875 nVidia - Quadro RTX4000 ATA - AMD Ryzen Threadripper PRO 7965WX 24-Cores - 128GB RAM
Message 6 of 11
TheCADnoob
"DID I MISS SOMETHING?"
it shows that the post was edited by the admin
CADnoob
Message 7 of 11
darawork
Is there a new Admin?
There hasn't been one here for quite some time now.
If AutoCad was making ellipses all over the shop, I'd be swearing too.
That post was edited by ADSK AI.
Darawork
AutoDesk User
Message 8 of 11
Well I am not sure what caused that responce but I can say that I have been able to finish the model and have sent out several RFQ's to have a 3D printed version made in either a fiber reinforced polymer or Direct Laser Sintering in eithe aluminum or stn. steel.
The attached files show some views of the part with the text imbedded in the surfaces of the part plus a view of the fractured part that my customer gave me in a bag which I then super glued together.
Message 9 of 11
jackshield
the OP refers to how the solid letters were created, but that content does not exist.
others pointed out that OP was edited, by admin.
Message 10 of 11
That information was part of the original conversation which I guess was not included in this.
Send me an email   gearknoxATnycap.rr.com
Message 11 of 11
Thanks for the comments Dara Work but a much less complex solution is to break the elipse into two parts.  With the gap at 0.002 in. the "letter", when 3D printed, will disapear.
