Lines intersecting when zooming.
Hi guys I have a problem lines keep intersecting while i scroll and correct themselves when I zoom in finally. Please can somebody explain to me what the problem is? How can I prevent this from happening? See photos below this is driving me nuts. Please help. AUTOCAD 2015. I have Regen, Purged, Audited. None helping.
Alfred.NESWADBA
turn off hardware acceleration (command _GRAPHICSCONFIG).
If that solves the display issue either stay with hw-acc off or update your graphic card driver.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Thank you so much Sir. It worked.
rkmcswain
See this KB article. Your display adapter may be at fault and/or not supported. Check all of the options/workarounds listed there.
