Lines go missing when lineweight display is on
ShifraSpiegel
ShifraSpiegel
Please see the images attached.
When lineweight display is turned on the wall lines go missing.
Please advise
ShifraSpiegel
Here are images
paullimapa
Try setting GFXDX12 to 0 and restart AutoCAD.
If that doesn't help enter command GraphicsConfig & change 2D Display Settings to another option and see if that makes a difference.
Paul Li
IT Specialist
@The Office
Valentin_CAD
@ShifraSpiegel ,
These suggestions may also help:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
vinodkl
Hello @ShifraSpiegel
This is bug in AutoCAD 2024 and its been fixed in the update 2024.1.2. Please install the update to fix this issue 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
ShifraSpiegel
Can you send me the link for the update
vinodkl
You can download updates from Autodesk Account by sign in.
https://manage.autodesk.com/products/updates
Please check this: https://www.autodesk.in/support/download-install/individuals/manage/update-your-software
