- Mute
- Permalink
- Report
Please see the images attached.
When lineweight display is turned on the wall lines go missing.
Please advise
Please advise
Here are images
Try setting GFXDX12 to 0 and restart AutoCAD.
If that doesn't help enter command GraphicsConfig & change 2D Display Settings to another option and see if that makes a difference.
These suggestions may also help:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Hello @ShifraSpiegel
This is bug in AutoCAD 2024 and its been fixed in the update 2024.1.2. Please install the update to fix this issue 🙂
Can you send me the link for the update
You can download updates from Autodesk Account by sign in.
https://manage.autodesk.com/products/updates
Please check this: https://www.autodesk.in/support/download-install/individuals/manage/update-your-software
