LInes do not meet in Autocad 2016
Message 1 of 20
Hi. There seems to be some issue with my cad. the lines when zoomed out seem to be meeting perfectly. but when I zoom in, I see they aren't meeting (the red lines in the attachment). Ortho is on. Snapmode set to 0. tried other values too but doesnot work. Snapangle is set to 0. Osnap is on and nearest is deselected. And it also makes a polyline with such non intersecting lines. If I try to hatch, it also takes in the hatch without any notifications of Closed boundary cannot be determined". Please help..
Accepted solutions (3)
Replies (19)
Message 2 of 20
imadHabash
Hi and welcome to AutoDesk Community,
such a problem causes by the user itself, i face it many times and the only reason that i found is the way of using object snap mode.i suggest to use (int) osnap for a while and see if the problem still exist.believe me you will find that the problem gone.why? because we use the right osnap on the right position.
try it and till us what you notice..
Good Luck..
Imad Habash
Message 3 of 20
I really did not get how it can take hatch and makes a polyline if these lines aren't meeting. and also that if in an active command I try to zoom in, it does not allow me to. similarly it does not allow me to zoom out with my scroll wheel if any command is active and I've zoomed in to the extent it shows in the image.
Message 4 of 20
It still does the same thing even if int osnap is on. I've kept mid point, end point, intersection, perpendicular, center, geometric center, node and tangent on. rest all are off including grid snap.
Message 5 of 20
imadHabash
@Anonymous wrote >> I really did not get how it can take hatch and makes a polyline if these lines aren't meeting <<  for hatching this usual CAD behavior and there is a system variable called HPGAPTOL and from HELP (The default value, 0, specifies that the objects enclose the area, with no gaps. Enter a value, in drawing units, from 0 to 5000 to set the maximum size of gaps that can be ignored when the objects serve as a hatch boundary ).
also when you want to zoom in and out REGEN will help you to go in or either out.
Note:
what about your hardware acceleration ...would you try to Disable it ?
Imad Habash
Message 6 of 20
I've turned off hardware acceleration and also checked with the value for HPGAPTOL. It is 0 but still I get the same issue. Attaching image for reference.
Message 7 of 20
imadHabash
Can you share us the problem ( put a mark ) as CAD file please?
Imad Habash
Message 8 of 20
I've also noticed that when I try to zoom in too much before it starts showing such non intersecting lines, sometimes my display tends to distort a bit. could this entire problem be a display bug or something?
Message 9 of 20
imadHabash
Is your AutoCAD updated to the latest Service Packs and Hotfixes?
Imad Habash
Message 10 of 20
how can I check about the updates and the service pack?
Message 11 of 20
Attaching the file. have circled the part with the problem.
Message 12 of 20
imadHabash
to know if the SP is loaded go to small arrow upper right of CAD screen beside the question mark (see images)
Imad Habash
Message 13 of 20
imadHabash
after opening your CAD file i notice another errors (green circles) this make me getting back to my (Post #2).what you are suffering from is caused by human errors.
Imad Habash
Message 14 of 20
The service pack shows M.107.0.0 AutoCAD 2016 SP1. I am not sure if its the latest one
Message 15 of 20
could you attach the file with those green circles? as this is what is happening even when ortho and osnap are on. such errors aren't visible unless I zoom in.
Message 16 of 20
imadHabash
yes.. i forget to download it Smiley Wink
Imad Habash
Message 17 of 20
this is what I have been trying to solve as these issues are in all my files at all corners. and this has been happening since a few days. I was not experiencing such issues before. if its a possible human error, why would it even form a polyline out of these lines. and apart from these, even if my ortho and osnap had been perfectly function, what would be the possible cause for this?
Message 18 of 20
and also when I gave the polyline command, I also noticed that the errors of non-meeting ends gets solved by itself as if the corners have been filleted.
Message 19 of 20
Michiel.Valcke
It is possible to create polylines if the other side of your line does connect correctly.
there are several ways to avoid or fix these issues.
As imadhabash already said; using object snap (OSNAP - F3) while drafting and carefully selecting which kind of snaps you want to have (END-MID-CEN-...) will greatly improve the quality of your work.
If you're drawing a line or polyline and don't have your object snap active you can shift+right click to select a snap for the next vertex of your line. Once you've placed that vertex, you will have no snaps active after that.
If you notice several lines not closing or joining, you can quickly join (J) + trim (TR) them by using the fillet (F) command with radius 0
For making a hatch you will allways need a closed polyline. Even if all the vertexes are connected that does not mean a polyline is closed. To close a polyline check the properties (PR)
Message 20 of 20
I guess I will upload a video in which I am constructing lines with proper snaps but it still gives me such lines.
