lines arent supposed to be there
I have the recent version up but I have lines running over the page that aren't supposed to be there at all. I tried rebooting. any suggestions?
ChrisPreece
Hi @Anonymous,
I see you're posting for the first time. Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD forum.
Try turning line smoothing off by using the LINESMOOTHING command.
If this post answers your question or solves your issue, please click Accept as Solution so others in the community can find it easily.
Chris Preece
Technical Support Specialist
They are still there when i turn off line smoothing. the lines are different colors, not part of my drawing- just showing up.
ChrisPreece
Hi @Anonymous,
Can you use the GRAPHICSCONFIG command and let me know what type of graphics card AutoCAD is using? While you're in that dialog box, try turning hardware acceleration off and see if that clears up the lines.
If that doesn't fix it, send me a screenshot of the GRAPHICSCONFIG window.
Chris Preece
