Lines are seen in preview before printing but are not seen in print
yaronw3
yaronw3
Lines are seen in preview before printing but are not seen in print\ are missing in the print.
All layers are not locked \freezed\ off.
Please help
Yaron
Alfred.NESWADBA
can you please
  • print to PDF using "DWG to PDF.pc3" and upload that PDF
  • upload the dwg-file
  • and describe us which lines you miss in the plotted PDF
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
john.vellek
Hi @yaronw3,
Is it possible that this is problem with the PDF Reader application you are using?  Sometimes hairlines can get lost at certain zoom levels. I, like @Alfred.NESWADBA, would like to see your drawing file (along with a plot style if you use one) and the resulting PDF.  This will help me to better understand what might be happening in this process.
John Vellek
john.vellek
Hi @yaronw3,
I am coming back to your thread to see if the issue or question you posed has been resolved.  If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
John Vellek
