Message 1 of 10
Line weights not displayed correctly
11:05 PM
I made a test with line weights, listing from 0.00 to 0.40 mm but for some AutoCAD only seems to display 3 line weights. Here is the test, and lwdisplay is set to 1:
However, when I generate a PDF with it (with autocad general documentation print) it does display correctly and you can actually tell the difference between 0.00 and 0.25 mm visually:
Is there a way to fix this and view the lines above (model) like the ones below (printed viewport)?
