AutoCAD Forum
LINE WEIGHT NOT SHOWING ON PDF OR MODEL SPACE
4 REPLIES 4
NEL15AS941219
12299 Views, 4 Replies
Hi
My (Lineweight) does not show on my -model space- or my -PDF- I have tried doing (Type PICKFIRST at the command line.  If it's "0", change it to "1")
but did not work on my me.
Any other solutions?
Kind Regards
4 REPLIES 4
PICKFIRST does nothing have to do with lineweights.
Can you please show your drawing + the PDF you get from that drawing, mark the object that you think has an incorrect lineweight.
If you used a CTB or STB, please upload that too so we can try to reproduce your result.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
steven-g
in reply to: NEL15AS941219
LWDISPLAY=1
imadHabash
>> My (Lineweight) does not show on my -model space <<
turn ON LWDISPLAY (see below image)
>> or my -PDF- I have tried doing <<
from plot dialog try to tick the box (see below image)
>> Type PICKFIRST at the command line. <<
pickfirst has no issue for you subject.
Good Luck..
Imad Habash
NEL15AS941219
in reply to: imadHabash
Yes thanks its showing now.
AutoCAD Inside the Factory
