Line weight not plotting
dvrVSNMW
Message 1 of 15
dvrVSNMW
I want to make a single line more heavy/thicker. So I thought I change the linetype in "layer properties" to 2.11mm but nothing changes when I plot to PDF.
Attach 1 -> settings
Attach 2 -> settings
Attach 3 -> PDF plot preview
Anyone any idea how to fix this ? How to get a line more heavy, more thick?
DVR
Replies (14)
Message 2 of 15
Valentin_CAD
@dvrVSNMW ,
Consider the suggestions from this link:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 3 of 15
pendean
Community Legend
Community Legend
Did you remember to turn on LWDISPLAY variable?
Then when plotting (and in Pagesetup command) did you remember to check the box labelled PLOT OBJECT LINEWEIGHTS?
Message 4 of 15
cadffm
we need to know your PLOT settings as well.
Sebastian
Message 5 of 15
dvrVSNMW
Where do I find my plot settings?
Message 6 of 15
dvrVSNMW
LWDISPLAY is on now but it does not print thicker lines on PDF. I do see the thinker lines in my drawing now.
I have PLOT OBJECT LINEWEIGHTS enabled.
Message 7 of 15
dvrVSNMW
I looks like every different color is set to a specific line type weight in this setting. I don't know if this has anything to do with it. (See attachement "55")
Message 8 of 15
paullimapa
You’ve encountered the classic debate between using ctb vs stb to control lineweights. Since you are plotting using ctb own assignments your lineweights have no impact. Read up on this thread
https://www.theswamp.org/index.php?topic=23950.0#:~:text=When%20plotting%2C%20the%20CTB%20file,to%20....
Paul Li
IT Specialist
@The Office
Message 9 of 15
dvrVSNMW
If I disable 'PLOT WITH PLOT STYLES" it gets thicker, but now the colors are a bit wrong on the file because, the plot styles are disabled.
An extra problem is that some lines are not think, which are on the label. This is so in the plot preview as in the drawing it self.  (See attachment)
Message 10 of 15
paullimapa
if you disable plot styles that means your ctb pen weight assignments are completely ignored. Then you’ll have to rely on defining a weight for each layer.
Again read the link I posted earlier.
Paul Li
IT Specialist
@The Office
Message 11 of 15
cadffm
the topic 'thicker or thinner' is explained (your Plotstyles in your .ctb are set to print with lineweight 0.2) now.
the next one:
>"some lines are not think, which are on the label."
Please, share a (partion) of this .dwg
Sebastian
Message 12 of 15
dvrVSNMW
Shared DWG in attachement.
Message 13 of 15
dvrVSNMW
It is all clear now for me. The CTB file is "king" here. Thank you very much everybody to help me out. Much appreciated !!!
Message 14 of 15
cadffm
Please share your Productversion(s) number(s) - the best way is, share your command: ABOUT dialog
to make sure you are running the latest update.
The Block TP2 - Detail Doorsnede 2023, Visibility 'F265-1200' isn't drawn as all other Vis
I can't see a real problem, but I can see a difference, so please: Is it working with other 'visibility1' (<-great  Parametername)
Sebastian
Message 15 of 15
ht23624
change ctb option "none" and check plot "plot object lineweight"
