Find and Replace - number of entries in pulldown
steveeLEW39
Observer Observer
steveeLEW39
Observer
Observer
First time to ask a question, usually I can find an answer by searching Google, but not this time
When using the find (and replace) dialog, the "Find what" and "Replace with" pull downs only hold 6 items and if a 7tth is entered, the first one entered is replaced
Does anyone know if there a system setting to increase the number of items these pull downs retain?
Thanks in advance for any answers provided
Valentin_CAD
@steveeLEW39 ,
This seems to be hardcoded instead of a user defined setting.
You may find other options in the AutoDesk App Store:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
steveeLEW39
Observer
Observer
Thanks for your reply, I figured that might be the case as answers are
usually easy to find on Google, but I thought I would ask anyway
Thank you
