Line type scale
Line type scale
Line type scale
I want to set LTS such that when i change or set my template scale then automatically LTS will get set to half of my sheet/template scale.
i.e. if my sheet/ template scale is 2 (scale X,Y,Z) then line type scale should automatically set to 1.
Alfred.NESWADBA
ScaleX/Y/Z for a block-insertion does not have anything to do with linetype-scale of objects within the block-definition.
So you can scale your block to any scale-value, the linetype will always have the same appearance (after _REGEN maybe).
If I misunderstood anything then please upload the drawing with the objects you are referring to.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
Hi @Anonymous,
I am not sure that I really understand the scaling issue of your template but you should be able to create either a LISP routine or an Action Macro that grabs a scale value and then sets the LTSCALE.
Please give me some more details so I understand your question more clearly. I am happy to try to provide a sample macro.
Or, you might add a post in the customization forum if you want to get a LISP routine/help. There might also be some add-ins in the Autodesk App Store that could help.
John Vellek
jackshield
if your placing your "sheets" on layout tab, set ltscale to .5 and psltscale to 1 and it takes care of itself
scot-65
If the title border is in Model Space:
One method to visually see what the LTS should be is to create
a dimension object and play with DIMLFAC override as well as
either a prefix or suffix.
For us, I show the Drawing Scale, DIMSCALE, LTSCALE, TEXTSIZE
and (MS) Plot Scale as 5 individual dimensions outside the printing
area. It is embedded into a dynamic block having a scale lookup.
When the scaling is to our liking, this block is exploded (and the
correct values are shown).
DMS: <>
For the workstations here that do not have the "Set environment
based on drawing scale" menu function, they know which settings
are for this particular file's scale.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Hello Alfred,
You understood correctly.
but my issue is with LTS, actually i prepared at least 10 drawings per day,
because of there geometries i need to change or play with sheet scale.
for my requirement I need LTS half of sheet/template scale.
I need lisp program or such setting that i did not need to worry about LTS when i change my sheet scale.
Thank you,
Regards, Abhijeet.
Hello John,
I prepare at least 10 drawing per day,
because of there varying geometry i need to change Sheet scale.
My requirement is establishing relation between sheet scale and LTS.
If my sheet scale is 1 then LTS automatically set to 0.5 (half of sheet scale)
Could you help me with micro or lisp program.
Regards, Abhijeet
