LINE TYPE/PATTERN CREATION
chaitanya.chikkala
chaitanya.chikkala
I WANT TO CREATE A LINE TYPE  OR PATTERN USING EXPRESS TOOLS  OF THIS TYPE --->   /\/\/\/\/\/\
IS IT POSSIBLE?
IF SO PLEASE GUIDE ME....
pendean
Community Legend
Community Legend
HELP in AutoCAD explains ho to create simple linetypes, you need one with the keyboard character/letter / and the keyboard character/letter \ just like you drew it here.
chaitanya.chikkala
But i want that pattern with required geometry....say...the angle between them should be 45degrees or 60 degrees, whatever i want....and the distance between the lower tip of those lines should be 0.9 or 1.8....whatever i want....
i want to know whether that is possible.....
pendean
Community Legend
Community Legend
Now you tell me LOL
MKLTYPE command may be of use but for the most part AutoCAD doesn't do that type of detail:
http://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/AutoCA...
You might consider creating a dynamic block instead is these will not be very long linetypes. Create a DWG file with a mockup of each of your linetypes and repost with all the details in the dynamic blocks forum here http://forums.autodesk.com/t5/dynamic-blocks/bd-p/154?nobounce
chaitanya.chikkala
I GOT THE SOLUTION FROM DYNAMIC BLOCKS FORUM....
EXPERTS IN THAT FORUM SUGGESTED TO CREATE A DYMANIC BLOCK WITH HATCH PATTERN INSIDE WHICH EXACTLY SUITED MY REQUIREMENT.
THANKS A LOT.....http://forums.autodesk.com/t5/dynamic-blocks/array-parameter-in-blocks-can-not-fill-the-left-over-sp...
