AutoCAD Forum
line turn in to a dotted line
6 REPLIES 6
1772 Views, 6 Replies
when i downloded a file of dwg to my autocad
it changed every line type that i have to a dotted line when i choose every line that i have on the every file
the file that i downloded is not a block
and i cant seems to fix it
sorry for my bad English
and thank you for your time
6 REPLIES 6
rkmcswain
Are you sure that is what is happening?
Objects can change their appearance when selected. This is to distinguish that they are selected. See below.
Patchy
😀 Did you click on the line? that's how it works, you don't like it use highlight command and change it.
in reply to: Patchy
yes this is what happened to me i just dont like it when its dotted, is there any way to change it back?
Patchy
HIGHLIGHT command, change to 0
in reply to: Patchy
it doesnt give me the option to write 0
in reply to: Patchy
thank you so much it worked!!!
AutoCAD Inside the Factory
