Line not highlighting when selected
Jaeppers
Message 1 of 22
Jaeppers
Usually when I select an existing line on CAD its fully blue and today I highlight it and it only shows the two end and middle points of the line.
In the photo one line is joined and other is a new line. Usually all lines are fully blue and now when I draw a new one its not.
Replies (21)
Message 2 of 22
Patchy
Let's see your .dwg
Message 3 of 22
Jaeppers
See attached.
Message 4 of 22
Jaeppers
I hit the wrong reply button but the file is the message board
Message 5 of 22
Patchy
It shows ok for me, try your graphic acceleration.
Enter the 3DCONFIG command and click the Hardware Configuration button. Enter the OPTIONS command or choose it from the Application menu to open the Options dialog box. On the System tab, click the Graphics Performance button. Then click the Hardware Acceleration button to turn it off or on.
Message 6 of 22
Jaeppers
So I turned it off and now if i select the line its still not highlighted and now its dashed.
Message 7 of 22
Patchy
and your HIGHLIGHT is set to 1?
Message 8 of 22
Jaeppers
Yes it is
Message 9 of 22
Jaeppers
Before the line problem it was working fine and then I accidently clicked into 3-D mode and then the line problem started after I clicked out of it
Message 10 of 22
Patchy
is it SELECTIONPREVIEW you're using?
Message 11 of 22
Jaeppers
Selection preview is set at 3.
Message 12 of 22
Jaeppers
Also when I select any text that I have it highlights red. Not sure if that can be fixed or not.
Message 13 of 22
Patchy
Probably has to do with graphic card driver needs update.
Someone here will have a link to it.
Message 14 of 22
Jaeppers
I figured out the color thing but the lines are still having the same problem
Message 15 of 22
Patchy
Let's try:
UCS, World then Plan.
Message 16 of 22
Jaeppers
How do I do that?
Message 17 of 22
pendean
Community Legend
Community Legend
@Jaeppers
Your "line" is a PLINE, like the other: do you just need to EXPLODE it?
What is your ABOUT command pop-up list as your exact AutoCAD year and variant?
Your WindowsOS version is...?
Can you also show us the GRAPHICSCONFIG command pop-up too please?
Message 18 of 22
Jaeppers
The about command comes up as CAD 2022 with Land/FX.
Windows is the most updated version I think
Message 19 of 22
Patchy
I missed the reply about to 3d then back to 2d.
The command:
UCS
W (for World)
then
Plan
Message 20 of 22
Jaeppers
All it did was zoom me out of model space
