Line in annotative block not scaling
jriseborough
Message 1 of 13
jriseborough
I have a block that annotative. Its a column bubble for grid lines in a building. The bubble and text scale to the viewport, but the grid line is a constant length. If I stretch it in my 1/8" viewport, then in my 1/16" its twice too long. How do I get it to scale right?
Replies (12)
Message 2 of 13
pendean
Community Legend
Community Legend
Place your block inside a DWG file that exhibits this issue then share that over here please @jriseborough
Message 3 of 13
jriseborough
Here you go
Message 4 of 13
pendean
Community Legend
Community Legend
Thanks for the file @jriseborough
Your dynamic block changes size (aka remain a consistent size all the time) when I change the annotative scale of the two viewports in your LAYOUT1 and LAYOUT2 here, just the way you want.
Are you perhaps not quite aware what the annotative feature does? aka "consistent size" in all viewport plot scales?
Or is it something else like the linetype spacing perhaps?
Message 5 of 13
jriseborough
Yes, thanks. I didnt have the viewport scale set.
Message 6 of 13
jriseborough
Ok, now I opened in a different version of autocad (ACAD23) and its not working again. Viewport scales set correctly.
Message 7 of 13
pendean
Community Legend
Community Legend
Still no issues here, I used AutoCAD2023, see attached.
Message 8 of 13
jriseborough
here are my plots. 1/16 and 1/8. the 1/8 does not extend the line
Message 9 of 13
pendean
Community Legend
Community Legend
You posted the same image twice @jriseborough
Sadly it does not change the fact that over here I cannot reproduce your issue in your files. Check your settings for ANNOAUTOSCALE and ANNOALLVISIBLE, mine are 4 and 0 respectively, and my graphics card regens in time with AutoCAD, if yours does not try forcing it using REGENALL command
Message 10 of 13
jriseborough
I guess I dont see it working for you either. Perhaps I am not explaining what I expect. For the 1/16" shown, the line in the block is across the second line on the left. For the 1/8" and 3/32" its not.  Shouldnt the line stay in the same relative place?
Message 11 of 13
jriseborough
Another thing i have noticed, is the block moves location in different scales.
Not sure how to stop that either.
Message 12 of 13
pendean
Community Legend
Community Legend
...Shouldnt the line stay in the same relative place?
That's a different question from the original: it all depends on the object's insertion point relative to the other content
And if you need to use ANNORESET command to remove any manual grip edits performed in some viewport scales so they all match up.
Message 13 of 13
jriseborough
Ok, I think I will end this post and start another with a better description of what I think should happen.
