AutoCAD Forum
Line Fade Out
7 REPLIES 7
Message 1 of 8
angusstevenson123
7866 Views, 7 Replies
Line Fade Out
Is there a way in Auto-CAD to fade out a line.
That is - a line is 100 percent visible - but then it slowly fades to nothing.
I am drawing some floor boards - and the boards need to fade out at the top of the drawing.
Thankyou,
Angus
7 REPLIES 7
Message 2 of 8
With a line? Not that I know of.
You can more or less fake this effect by using a really thin HATCH object,using a gradient fill, as shown here.
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 8
you can use TRANSPARENCY option either from Layer Manger or from Properties.
if do you want to notice that while you're working make sure that TRANSPARENCYDISPLAY is (1).
Imad Habash
Message 4 of 8
rkmcswain
in reply to: imadHabash
How is that going to provide a fade effect from one end of a line to another? Thanks.
Message 5 of 8
Thanks for your input - appreciate it
Message 6 of 8
For the line fade out - thin hatch with a gradient fill..........
Would you mind expanding on this? Go into a step by step?
I thought I had it in the bag - but when playing with hatch/ gradient - I couldn't quite get the desired effect of the hatch fading.
Thankyou
Message 7 of 8
Seemed worthy of a new post. See if this helps.
Message 8 of 8
Make some long and very thin closed-Polyline Rectangles.  Hatch them with a gradient [you should be able to figure out the direction of gradation, etc., by trial if it's not obvious within the Hatch controls] by object selection, not picking inside areas [since those areas will be so narrow as to be difficult to pick in].  Erase the rectangles, or put them on a Layer you can turn off, or something.  Is that enough?
Kent Cooper, AIA
State of Sustainability Webinar
AutoCAD Inside the Factory
