Line error when importing image.
minhnguyen192nm
minhnguyen192nm
I have a question about the following case, I hope to get help from experienced Autocad club friends! I have an image file that I converted to Cad, but the line is turned into a curve. I want to ask is there a way to turn this curve into a straight line, because my image file is pixelated, so I can't export through cad the house image. I want to ask the Autocad club, is there a way to fix the curve in this picture below to a straight line? I thank you in advance!
paullimapa
Which of these options have you tried to import the images into AutoCAD as a vector file:
https://www.scan2cad.com/blog/dwg/converting/convert-image-autocad/
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
That would be a flaw in the conversion tool/method you used I suspect. Is manually fixing it in AutoCAD not an option? Using a different conversion tool(s) would be the other things to try.
May I ask, are you using the RASTERDESIGN add-on in AutoCAD to help? It is free to install and use for anyone in an active subscription of AutoCAD. it's not a conversion tool per-se, but it is a different way to incorporate images into DWG files and use/fix where needed.
minhnguyen192nm
Thank you so much for your support!!
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
minhnguyen192nm
Thank you for your suggestion, it was very helpful for me!!
