AutoCAD Forum
cant open file type auto cad drawing interchange
11 REPLIES 11
Message 1 of 12
dalbandit
792 Views, 11 Replies
as title suggests i need to open the file so i can copy to shapes to cnc machine
Labels (1)
11 REPLIES 11
Message 2 of 12
@dalbandit,
  1. Click File menu > Open.
  2. In the Select File dialog box, in the Files of type box, select DXF (*.dxf).
  3. Find and select the DXF file you want to import, or enter the name of the DXF file at File Name.
  4. Click Open.
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 3 of 12
done that but it doesnt show nothing, just like opening a new drawing,
theres data in the file because there memory is at 312 kb  and the pdf version has the drawings but when i load them into cad i cant modifiy any thing
Message 4 of 12
@dalbandit, Can you share the files..?
Thanks and Regards,
Rushabh Thakkar.
Message 5 of 12
I’ll give it a Go
Message 6 of 12
pendean
in reply to: dalbandit
@dalbandit Zoom>Extents and panning around usually brings file content into view for all of us: try that.
Message 7 of 12
doesnt let me attach the file
Message 8 of 12
dalbandit
in reply to: pendean
unfortunally im quite show that there is'nt any content on the page
Message 9 of 12
pendean
@dalbandit ZIP the file, come to the site, to share it.
If it is empty, then you received an empty DXF file, not much you can do about it sadly as the recipient. Reach our to the file sender and you both explore other options. You can also use web browsers all over the web to verify content too https://www.google.com/search?q=free+dxf+file+viewer
Message 10 of 12
dalbandit
Take a look
Message 11 of 12
paullimapa
just need to look at AutoCAD's command prompt & you'll see why this dxf is no good:
Paul Li
IT Specialist
@The Office
Message 12 of 12
cadffm
Tell the creator that the file is corrupt,
(content if the first and last line, and if i am rifght - also the file encoding is unusual)
I guess the used program, which saves or exported the file, works wrongly.
Fixed file attached.
Sebastian
AutoCAD Inside the Factory
