line drawing autocad 2016
Message 1 of 13
I am working through Autocad 2016. I am trying to draw using co-ordinates.  How can I change between relative and absolute co-ordinates. 2,2 to 4,2 should be horizontal line. It us using relative co-ordinates.
Replies (12)
Message 2 of 13
Michiel.Valcke
I you turn of your dynamic input (_DYNMODE set to -3) you can draw a line by inputting the X,Y coordinates for every vertex in the command bar.
Message 3 of 13
Thanks. I have entered _DYNMODE on the command line and it states <3>. Don't know what values to type in. Is there nothing I can do from any of the menu systems
i have a File/Edit/View menu and a Home/Insert/Annotate as well as the Big red A
Message 4 of 13
No things have gone from bad to worse. when I enter line mode and enter 2,2 I get a line which stats of the drawing area. very low and left not above the origin markers
Message 5 of 13
kadmonkee
on the Status bar bottom of your AutoCAD screen
Right click on the Icon and select DYNAMIC INPUT SETTINGS
select the Settings button on the Pointer Input you can change how you want your coordinates to be used here.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 6 of 13
Michiel.Valcke
The value you type to completely turn of dynmode is: -3  or 0 (as opposed to the standard value of 3)
You can find more information about it here.
Message 7 of 13
I don't have the +_ symbol/ button on the bottom line. I have 'Display drawing grid'  'Restrict cursor orthogonaly'  'Restrict cursor to specific angles'
The button you show is not their.
To draw a box I AM FORCED UNDER aUTOCAD TO DO
Line 5,5   10,0   0,10   -10,0    0,-10
EVERY THING has to be relative to the last point.
I should be able to do
Line 5,5   15,5   15,15   5,15   5,5
 Your status bar is difrent to mine and mine was a fresh install without any changes made. Autocad default?
Message 8 of 13
beyoungjr
You must use the "Hamburger Menu" (thanks Lynn Allen for that nickname) to turn the icon display on for Dynamic Input.  The "Hamburger" is the 3 horizontal line icon on the far right edge of that bottom toolbar area.
Blaine Young
Senior Engineering Technician, US Army
Message 9 of 13
kadmonkee
on the Status bar at the very Right end find the customization button (3 horizontal bars) see image below
select the button and a window will open anything that is unchecked is not going to display. simply select it to display it.
by default it is turned off
thank you
Message 10 of 13
JDMather
@Anonymous wrote:
....  How can I change between relative and absolute co-ordinates. ....
You can force absolute with # symbol.
@Anonymous can force relative with @ symbol.
Message 11 of 13
dgorsman
While most AutoCAD old-timers know about the "@", it seems not many are aware of the "#".
Message 12 of 13
Thanks. That does work. typing Dynomode at the command input doesn't seem to work. However on the drawing area if I type 5,5 I get a line that starts 2 large grid squares up and right (a large square is made up of a 5 by 5 small squares). How can I resale this so it is only 5 small squares up and right, I.E. one large square?
Message 13 of 13
Alfred.NESWADBA
It's called DYNMODE, not dynOmode.
AutoCAD (with default settings) has not limited drawing area. The object might be outside the displayed area .. .and therefor please use the zoom functions, either by mousewheel or using command _ZOOM
If you want to scale an object then use command _SCALE, if you don't know how to use it please first use the help by starting the command and then press <F1>.
If you don't know the command then start the help using <F1> and search for "scale".
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
