Line Command Not Work Properly
When i am going to use line command it work but very slow like as a video call at slow internet connection or slow motion. So what is the wrong with me. If it is graphic problems, my laptop is MSI Apache pro (GE60 2PE) . Core i7, 2gb graphic, 8gb RAM so please help me guys. But all command are work perfect, some time when i use many selection it like too. And also printing is too slow.
Video of my problems
imadHabash
Try to check Graphic performance from... option -> system -> hardware acceleration.
Imad Habash
nestly2
Does the same thing happen in all drawings?
Is it better if you move closer to the origin  (0,0) ?
Does it make any difference if the Properties Palette is Closed or undocked.
Try docking the Command Line.
But sir there are no option to change my graphic card there are only shows intel graphic.
pendean
Community Legend
Community Legend
The instructions above are for you to change how AutoCAD interacts with your graphics card from inside the program: Try again, here it is edited with more information
"Try to change Graphic performance from... start OPTIONS command -> go to the SYSTEM tab -> select the hardware acceleration choice and edit/change the settings there"
