Layout wrong dimension position and scale
jim78b
jim78b
I have to print with a window from the layout, I have attached the 2 images. in one as is the original and in one as is after I preview.
the dimensions are not positioned correctly ...
imadHabash
There are many settings that we need to see and check ( scale factor ) .. would you please attache here the CAD dwg file itself for testing ?
Imad Habash
jim78b
i attach the drawing, you must go in layout, print preview.
imadHabash
Your issue will resolved if you took the whole viewport as a window for plotting preview .
Imad Habash
jim78b
OK THANKS for help me, but why this happen? i want know!
best regards
imadHabash
I suggest to make another layout space with new viewport , any changes ?
Imad Habash
