Layout TOOLS Tab missing
Message 1 of 8
Hi
I downloaded AutoCad 2020 yesterday for a University project. I need to add a north arrow and scale to my design. From my research this is achieved through a tab called "layout tools" under the Ribbon-contextual tab states-layout tools in acad.cuix. However this is not an option when I look for it. I have checked the other forums and this seems to be a very common problem.
Cheers
Replies (7)
Message 2 of 8
imadHabash
Honestly I didn't hit your point .. BUT as much as I understand your issue .. Layout tab didn't appear up there in ribbon till you switch from Model layout to layouts space .
Imad Habash
Message 3 of 8
pendean
Community Legend
Community Legend
LAYOUT tab in the RIBBON only appears when you are in a Layout, not modelpace.
>>>...I need to add a north arrow and scale to my design...<<<
And there are no LAYOUT TOOLS with north arrows in them.
Did you download the correct software in the first place?
Message 4 of 8
Valentin_CAD
@Anonymous ,
Welcome to the AutoCAD forum.
@Anonymous wrote:
... However this is not an option when I look for it. ...
There are sample North arrows and scales if you have AutoCAD Map 3D - see attached files.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 5 of 8
Hi guys, thanks for the help. I think I was a bit confused and I have just decided to make my own scale blocks and noth arrow blocks and insert them into my layout that way.
Message 6 of 8
willXXXDP
I had the exact same issue. You just have to install AutoCAD Map 3D from your Autodesk Desktop App, restart Autocad and it should be there!
Message 7 of 8
marcbrac
This the answer that I got today :
AUTODESK • 2088 ANSWERS • 100% HELPFUL
Hi Marc
I am sorry but the "Layout Tools" tab is not available in standard AutoCAD or AutoCAD LT.
To access those features you will need to use AutoCAD Map 3D or AutoCAD Civil 3D.
Dan
Message 8 of 8
j.lagdaan
Community Visitor
Community Visitor
Hi Autodesk,
If I may express my suggestion to modify your layout tab that can change or to have a color tab like an Excel sheet layout.
I believe a lot of Autocad users would love this.
Thank you,
Jonathan
