Layout Scaling Issue
Message 1 of 15
Hello all,
I exported floor plan layouts from the master file to create an individual dwg file for each floor plan. Then I opened one of the newly created dwg files. The drawing had a scale of 3/32:1, so I then imported the layout with the titleblock from one of the previous completed projects which had the same scale. However, the drawing looks too small in the newly imported layout despite being on the same scale. Can anyone tell me how to address this issue? Am I missing some trick here? Thanks.
Replies (14)
Message 2 of 15
ennujozlagam
check your ddunits every drawings must be the same before you import. thanks
Message 3 of 15
imadHabash
HI,
it depends on your drawing system variables like INSUNITS  >> Click << and/or -DWGUNITS command .
Imad Habash
Message 4 of 15
GrantsPirate
What was your method for exporting the drawings?
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 5 of 15
Thanks for your reply. I tried the solution you suggested but it did not work. I am attaching jpeg files for your reference. From the "master file" I exported the layout using "EXPORTLAYOUT" command to create individual file for the floor plan. Then from the previous completed project, I imported the layout to this newly created individual file by clicking right click on the layout tab>from template. I've checked ddunits for all the files and it is same. But still you can see in the "individual exported file" the drawing looks to small for 3/32:1 scale. Please advise.
Message 6 of 15
I've attached the CAD files for the same if that will help you.
Message 7 of 15
ChicagoLooper
This is an easy way. Do this.
  1. For the Master file, perform a SAVE AS and save it with a suffix like '_100' don't over write the original Master file, you are creating a copy.
  2. Next, perform a SAVE AS on Master file_100.dwg and name it B1. Delete ALL layout tabs except B1. You can delete a tab by right-clicking and DELETE. If you use CNTL+right click, you can delete multiple layout tabs.
  3. Open Master file_100.dwg and perform a SAVE AS and name it B2. Delete ALL layout tabs except for B2.
  4. Open Master file_100.dwg and perform a SAVE AS and name it B3. Delete ALL layout tabs except for B3.
  5. Repeat the above steps as necessary.
Chicagolooper
Message 8 of 15
If I understand correctly, you exported layout(s) to model, creating a new, separate file for each one(?)
If yes, all entities that existed in paper space are now in model space, exactly the size they were in the original file.
Viewports have now become polylines, exactly the size they were in paperspace
Objects that were shown in viewports are scaled down as they "appeared" in paperspace. If VP scale was 1(paperspace unit)=10(modelspace units), objects will need to be scaled up 10X to be the size they were in modelspace in the original file, etc for whatever scale original layout has.
Hope this helps, if not let us know what else you need.
Message 9 of 15
This is exactly what happened. Can you tell me how to scale up the drawing without changing the scale? Is that even possible?
Message 10 of 15
I've attached the dwg files in this thread. Can you have a look at that?
Message 11 of 15
In this case, none of the "typical" methods seem to work as the original objects aren't "precise"
If you change "units" to decimal, and increase the precision, you will see that objects aren't exactly the size represented by dimensions or properties when units are set to fractional with 1/16" precision.
You can either use @ChicagoLooper 's method, or go into the viewport(s) of each layout and copyclip all objects, and then pasteclip into a new file, then add title blocks and other paperspace objects as desired.
I did this method with the attached file, see if it works for you.
With the slight error in precision, scaling up by reference multiplies the errors tremendously, and scaling by a ratio (12/.09375) produces the same result....
Message 12 of 15
GrantsPirate
If this is something you have to do on every file and every layout then maybe you can change your work flow.  Scale the titleblock in layout for the 3/32 scale (as an example), then create your viewport at 1:1 scale.  Work as normal and use exportlayout.  No scaling required.
GrantsPirate
EXPERT ELITE MEMBER
Message 13 of 15
ChicagoLooper
Try this:
  1. Open FP BASE.dwg=>right click any layout tab=>select From Template from shortcut menu. Image-1.
  2. Change File of Type to Drawing (*.dwg)=>Browse to and select FP BASE_B3.dwg=>Open. Image-2.
  3. Choose Layout3-Layout1 then OK. Image-3.
  4. A new layout tab named Layout-Layout1  will be added to your drawing. Image-4.
Image-1.Image-1.
Image-2.Image-2.
Image-3.Image-3.
Image-4.Image-4..
You may re-name the new layout tab. You may delete all other layout tabs. Save this drawing using a NEW name. Repeat as necessary.
Chicagolooper
Message 14 of 15
Thank you for sharing this. Its been a great help. I did exactly the same thing as you told me to do. Now, I have all the layouts thee way I wanted. However, now I am facing another issue. When I try to print it, the titleblock which I added from the another project is getting printed full size. First, it appears the unreconciled layer message (see attached). After I reconcile all the layers and try to print it, its not coming in full (see attached.)
Note: None of the layer is on non plot layer.
Message 15 of 15
Got this. In the print page set up, the plot setting was for window. After changing it to extents, it is now coming full. Thank you
