About number of objects limit
fpdpzkCDGGL
fpdpzkCDGGL
Community Visitor
Community Visitor
I'm using AutoCad2020 as student edition.
i'd like to make 3750 X 3750 array of circle using 'array' command.
but it seems there is limitation for number of objects as 100,000.
i found some helps about this problem, it said using 'setenv "MaxArray" "n" '  command.
but in my AutoCad, if i use 'setenv' in command line, it shows 'unknown command'.
how can i modify the limit for number of objects?
ennujozlagam
you can refer to this LINK and see if helps. thanks
cadffm
Don't forget the brackets
Command: (setenv .....)
Sebastian
j.palmeL29YX
The maximal permitted value for MaxArray is
10.000.000 (if I remember right),
but 3750x3750 is
14.062.500
You must use smaller values for the array.
Jürgen Palme
ВeekeeCZ
User the COPY command with its ARRAY option.
First to the horizontal, the second to the vertical direction.
But you might still wait for ever for the computer to draw it.
j.palmeL29YX
Question OT:
What will this array of 3750x3750 circles be used for?
Jürgen Palme
