Layout Dashed Line
Layout Dashed Line
dcnkzr
Layout Dashed Line
dcnkzr
Hi everyone
What does mean this dashed line on Autocad Layout and How can I Align my titleblock to the page edges exactly
imadHabash
@dcnkzr
The dashed line layout represents the non-printable margin. To align your title block to the actual page edges, adjust your page setup margins to zero or use precise coordinate insertion. >> Click <<  >> Click1 << >> Click2 <<
Imad Habash
ChicagoLooper
@dcnkzr
That dashed line represents AutoCAD's non-printable area.
You can PUSH that dashed line all the way to the edge of the sheet to optimize your printing area. Choose your sheet carefully. Select Full Bleed for best results.
1.1.
Compare image above with a Full Bleed sheet.
2.2.
To establish Osnaps at the corners of your Full Bleed sheet, draw a rectangle the same size as your sheet, e.g. W11"xH8.5. Put this rectangle on a non-printing layer then move it so the lower left corner is at 0,0. Next, do this:
3.3.
Finally, complete your setup by placing your titleblock at the desired location.
Chicagolooper
pkomatlapalli
Hi @dcnkzr,
Did the suggestions provided by imadHabash and ChicagoLooper help answer your question?
If one of the replies helped resolve your issue, please consider marking it as an Accepted Solution. This makes it easier for others facing the same problem to find the answer quickly.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question and can suggest next steps that may be helpful for you to achieve what you're looking for.
Pavan Kumar | Community Manager
