Layout cut off on print to PDF
Message 1 of 9
I am creating a new 11x17 border/title block for our firm.  It plots to a laser printer and PDF just fine for me on my PC (ACAD 2015).  I use the ACAD DWG To PDF.pc3 plotter file for creating PDFs.  A colleague uses the exact same plotter file.  When we put the new drawing on his PC (acad 2016) it prints just fine to the laser printer.  But when he prints to PDF (sing DWG To PDF.pc3) the right end of the border and title block get cut off the entire height of the page.  Is there a setting somewhere in the DWG To PDF.pc3 file where I set a pritner margin for that "driver"?  I'm assuming that's the issue - I just can't find where such a setting would be.
Thanks!
Steve
Replies (8)
Message 2 of 9
Found it!
ACAD menu
Print
Manage Plotters
Double click "DWG To PDF.pc3"
Device and Document Settings tab
User-Defined Paper Sizes & Calibration
Modify Standard paper Sizes (Printable Area)
Select "ANSI expand B (11.00 x 17.00 Inches)"
Click Modify
Change printable area (in our specific configuration case) to:
TOP - .17
BOTTOM - .03
LEFT - .25
RIGHT - .03
And fixed!
Message 3 of 9
sthompson1021
I was just getting ready to reply when you posted your solution. I use 2014 for everyday work but I do have 2016 on my computer. I noticed that our titleblocks were getting cut off with 2016 to and checked the margins and they were the same between 2014 and 2016. Adjusting the margins on 2016 worked but I found that using ANSI full bleed B (11x17) also worked. Just not sure why the same paper size with the same margins would give 2 different plots but 2016 dwg to pdf has other issues too from what I've been seeing on the forums. Anyway glad you got it figured out.
Message 4 of 9
acramerWSZRE
I am having the same trouble but I am using Nuance to print to PDF.  Any help with this would be great.
Message 5 of 9
Alfred.NESWADBA
Any reason why not trying the steps shown above with "DWG to PDF.pc3"?
It is marked as solution so I guess it's worth to try it. 😉
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 6 of 9
acramerWSZRE
I wasn't sure if it would be able to combine the dwg to pdf file with a regular nuance pdf file but it worked.  I had to play around with the borders to get it to match the other but all in all it is working.  Thank you.
Message 7 of 9
Alfred.NESWADBA
Great, good to know it's working well for your now 😉
Thx for feedback!
- alfred -
Alfred NESWADBA
Message 8 of 9
todd.eckrich
Observer
Observer
Thanks for posting your solution.  I wasn't able to use negative numbers to modify the printable area but setting them to 0 worked!  The original settings printed SHX fonts just fine but would not print True Type ones along the top and right edges of the drawing.
Message 9 of 9
MichaelSanJose
When I print I have no issues but when I PUBLISH, multiple sheet layouts or a single layout, I get extra "border" lines.
