layout create view error
Message 1 of 9
hi,
I don't know why in layout create view,
when pull up should be top view & SW isometric , but its show bottom view & SW isometric.
Replies (8)
Message 2 of 9
imadHabash
it depends on selecting the parent view . please try read more here . >> Click <<   >> Click1 <<
Imad Habash
Message 3 of 9
@imadHabash
[when pull up should be top view & SW isometric , but its show bottom view & SW isometric.]
Message 4 of 9
imadHabash
i think that you should change the Orientation to another one than Front ( Top  )
Command: VIEWBASE
Specify model source [Model space/File] <Model space>:
Type = Base and Projected Hidden Lines = Visible and hidden lines Scale = 10:1
Specify location of base view or [Type/sElect/Orientation/Hidden lines/Scale/Visibility] <Type>: o
Select orientation [Current/Top/Bottom/Left/Right/Front/BAck/SW iso/SE iso/NE iso/NW iso/cuStom] <Front>:
Imad Habash
Message 5 of 9
Hello!
None of my problems have been solved yet
Message 6 of 9
Bob_Zurunkle
OP have you checked to see if you are using first angle projection or third angle projection in your drafting settings?
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
Message 7 of 9
@Bob_Zurunkle
Hi, are you mentioned about this? where to check the angle?
Message 8 of 9
Erense
You can find this setting on the Home Tab, on the 'View' panel click the diagonal arrow (rightbottom)
Here you can check/change the First angle/Third Angle projection of the drawing like @Bob_Zurunkle mentioned.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
Message 9 of 9
@Erense
Problem solved. Thank you.
