Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
layout changing shortcut
Message 1 of 12
I use the heck out of CTRL+Page Up and CTRL+Page Down. I'm wondering if there is a way to change the shortcut keys or create new ones so I can use it with just my left hand on the left side of the computer like almost everything else that I do.
Would be much appreciated!
-Michael
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
Nope, there are no "pages" in AutoCAD.
But there are PAN UP, PAN DOWN as well as PAN LEFT and PAN RIGHT macros defined in CUI command that you can assign to buttons or keyboard button combos in CUI.
Message 3 of 12
Oh, I'm sorry I wasn't very clear. I meant the CTRL+ Page Up/Down shortcuts for changing layouts. I cycle through my layouts constantly and I'm just looking for a little quicker way.
Thanks! 🙂
Michael
Message 4 of 12
ВeekeeCZ
You probably cannot change these shortcuts or add new ones.
But, unless you're on LT, we could write a LIST routine that would do the same. Then you could assign any keystrokes to that.
Message 5 of 12
RobDraw
Most people call them layouts.
Rob
Message 6 of 12
BrianBenton
I'm not sure to make that any faster. CTRL+PAGE UP/DOWN is pretty fast. However there are other methods to switch between Layout Tabs in a file. Click the exact Layout you want to switch to it. Or in the File Tab, mouse over to display a thumbnail of the files Layout Tabs and click the one you want to go to. This method takes the computer longer to process it. I hardly use that one myself unless it's an accident!
But one method you might be able to do is to get a programmable mouse with extra buttons. Program one button for CTRL+PU and another with CTRL+PD.  Then that becomes one click without any arm/hand movement.
Brian C. Benton
[email protected]
http://CAD-a-Blog.com
twitter.com/bcbenton
www.facebook.com/CADaBlog
Message 7 of 12
ВeekeeCZ
Here are suggested routines. HERE how to work with LISPs. HERE how to create a custom command where field 'macro' would be filled with a routine name: LayoutNext or LayoutPrevious.
(defun c:LayoutNext nil
  (setvar 'ctab (cadr (member (getvar 'ctab) (append '("Model") (:LayoutsRealOrder) '("Model")))))
  (princ)
(defun c:LayoutPrevious nil
  (setvar 'ctab (cadr (member (getvar 'ctab) (append '("Model") (reverse (:LayoutsRealOrder)) '("Model")))))
  (princ)
(vl-load-com)
; pbejse https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/layout-order/td-p/3749964
(defun :LayoutsRealOrder (/ order)
  (vlax-for lay (vla-get-layouts (vla-get-ActiveDocument (vlax-get-acad-object)))
    (setq order (cons (list (vla-get-name lay)
                            (vla-get-taborder lay))
                      order)))
  (mapcar 'car (cdr (vl-sort order '(lambda (j k) (< (cadr j) (cadr k)))))))
Message 8 of 12
Kent1Cooper
Well, @ВeekeeCZ got in while I was coming up with this, but here's my somewhat simpler version:
(defun c:TabN (/ tab tabs)
  (setq tabs (layoutlist) tab (getvar 'ctab))
  (setvar 'ctab
    (if (member tab (list "Model" (last tabs)))
      (car tabs); then
      (cadr (member tab tabs)); else
    ); if
  ); setvar
); defun
(defun c:TabP (/ tab tabs)
  (setvar 'ctab
    (if (member tab (list "Model" (car tabs)))
      (last tabs); then
      (cadr (member tab (reverse tabs))); else
    ); if
  ); setvar
); defun
Assign them to shortcut key combinations as you like, or give them different command names that are only-left-hand combinations.
What's simpler is that they cycle in creation order, which isn't necessarily the displayed sequence of the tabs at the bottom, as BeekeeCZ's and Ctrl+PgUp/PgDn do it.
They also assume, because of your Topic wording, that you don't want "Model" included in the cycling, though if you're in Model space when you call one of them, it takes you into the Layout tabs.  Curiously, I find that Ctrl+PgUp/PgDn don't  "wrap" around the end and take you to the other end of the series, but these do  [again, omitting Model space, once they're into Layouts], as do BeeKeeCZ's commands.
Kent Cooper, AIA
Message 9 of 12
This is perfect. Thank you! I didn't know that you could just type in a lisp command name in the macro field for shortcuts.
Thanks much!
Michael
Message 10 of 12
Thanks for the help Kent,
Your lisp worked fine, but I do like the BeekeeCZ's feature of cycling through the current order of layouts rather than the creation order. We often add layouts later in the middle so it would be kind of wonky for me.
But thanks again!
Michael
Message 11 of 12
adeel3344
Observer
Observer
wao
Message 12 of 12
adeel3344
Observer
Observer
wao. thanks
