layout and Model tabs are toggled off, supposed to show buttons on status bar
GrantsPirate
Mentor Mentor
Message 1 of 10
GrantsPirate
In Options you can toggle off display of Layout and Model tabs, and then buttons are supposed to show in the status bar.  I toggle the tabs off but nothing appears in the status bar, 2018 or 2019.  Does this actually work and if so how to get it to show?
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Replies (9)
Message 2 of 10
RobDraw
Rob
Message 3 of 10
GrantsPirate
Rob - that button is not the same as the layout tabs.  Picking PAPER on the status bar will put you into a viewport and not toggle you to a Layout.  If that is what help is talking about then they need to update their help file because those are two separate functions.
GrantsPirate
EXPERT ELITE MEMBER
Message 4 of 10
S.Faris
Is this what you are looking for?
SALMANUL FARIS
Message 5 of 10
RobDraw
You are correct. I should have tested before posting.
I found an image of what should show up but cannot figure out how to turn them on.
Rob
Message 6 of 10
GrantsPirate
Rob - Yes that is it, I think I have seen that before, I wonder if it is a bug or there is another sysvar to toggle that?
GrantsPirate
EXPERT ELITE MEMBER
Message 7 of 10
RobDraw
It might be that it's a feature that is no longer available. Maybe it happened when the status bar and the quick access bar were merged.
Rob
Message 8 of 10
GrantsPirate
S.Faris - No, see post #4.
GrantsPirate
EXPERT ELITE MEMBER
Message 9 of 10
GrantsPirate
If you hover over the area in Options it still describes the buttons appearing, see image.
GrantsPirate
EXPERT ELITE MEMBER
Message 10 of 10
RobDraw
Yeah, I saw that. If my theory is correct, that would be an oversite on Autodesk's part, not editing the tool tip.
Rob
