Layers issue
Layers issue
Layers issue
On my screen under the layers box , we always see the list of the created layers... now they all have disappear! How do I do to get the list back to show
imadHabash
Hi and Welcome to AutoCAD Forum,
as i understand your need ... you may need from Layer dialog to press settings button (see below image) and start check boxes that you need.hope that what you're asking for.
Imad Habash
RobDraw
It sounds like you may have inadvertently checked the invert filter button.
Rob
Kent1Cooper
See the choices about Filters at the upper left of the Layer Manager:
Kent Cooper, AIA
This is a AutoCAD LT and I can't find the Filters icon on the layer box anywhere 😞 help!!
Kent1Cooper
I don't have LT, but the term "layer box" could have different meanings.  If  it's set up like full AutoCAD, then:
Filtering in the Layer Properties box [or panel or manager or palette or whatever you want to call it] controls which Layers are displayed, not only within itself but also in the Layer pull-down list, where you won't  see Filter options.  If LT doesn't have those same possibilities, someone who has it will have to take it from here.
Kent Cooper, AIA
