Layer states bug in AutoCAD 2025
sivan_abugov
sivan_abugov
Hey,
I've installed AutoCAD 2025 and opened my usual working file.
I'm encountering an issue where the l list only appears partially in the dropdown menu:
However, when I access the menu, all the states display correctly.
The problem seems limited to the dropdown list not showing the full list of layers...
and it happened only in 2025 >>>
Valentin_CAD
@sivan_abugov ,
Try this:
AutoCAD 2022 Help | MAXSORT (System Variable) | Autodesk
Related:
Layer Properties Manager palette is blank or black in AutoCAD (autodesk.com)
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
pendean
Community Legend
Community Legend
.... and a popular random makes-no-sense fix that seems limited to all 025 versions: set GFXDX12 to 0 (that's a zero), then restart the program. See if by some quirk that fixes your display-only issue.
