Layer Properties Manager
Titanium5
Message 1 of 9
Titanium5
LayerPropertyManager box.PNGmissing the settings icon (gear to the right of the Toggle Override highlight)
Replies (8)
Message 2 of 9
MatiasWendt
Hello...
already restarted the software?
did you notice when this error started to occur?
make sure all updates for your software are installed...
Se a resposta resolveu o seu problema clique em ACEITAR SOLUÇÃO, isso ajuda os outros usuários a encontrar rapidamente uma resposta, e se gostou, cliquem em CURTIR.
Matias I. Wendt
YouTube | Facebook | LinkedIn | Instagram
Message 3 of 9
Titanium5
Hi Matias,
1. restarted software & restarted PC more than once.
2. it started when I tried to add the missing icon and all I get is a tiny little dot; not the full gear icon.
3. all software updates have been installed.
Message 4 of 9
vinodkl
Hi @Titanium5
Type in the command "CLASSICLAYER". Do you see the setting option now?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 5 of 9
MatiasWendt
try resetting your Autocad settings
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
Matias I. Wendt
Message 6 of 9
Titanium5
Why do I need to go around? why doesn't the program simply display the gear correctly?
Message 7 of 9
Valentin_CAD
@Titanium5 ,
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 8 of 9
Titanium5
Thank you for the suggestions. Unfortunately, it didn't fix the issue. However, I will learn to live with the workaround.
Message 9 of 9
pendean
Community Legend
Community Legend
@Titanium5 Select a different workspace: does LAYER appear? If yes, go back to your workspace and see if that reset it.
If not, read this for other things to try https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Layer-...
