Layer Properties Manager displays all line weights as default
Message 1 of 8
Greetings, I am not sure if anyone has encountered this problem before. I have old drawings from my office with line weights that were set to the old pen plotters. I am trying to bring over all of the layer properties from 2014 auto cad to 2017 auto cad. I able to bring over all the properties, but the line wights all of which have been switched to default line weight. I still have all the original templates and drawings but I can get the lightweight numbers for the layers what am I doing wrong?
Replies (7)
Message 2 of 8
cadffm
From 2014 to 2017 you have to do nothing, so what are you doing and why?
If the lineweight is set to 0.09 in 2014 it still 0.09 in 2017.
Sebastian
Message 3 of 8
I thought that as well but for some reason, it changed all line weights to default when I brought over the templates
Message 4 of 8
cadffm
Please share the "old" file with lineweights /= default and the new file with all lineweights=default.
And if possible a screenshot where you show the lineweights  (do you have 2014 still running and can see the lineweight there?)
Sebastian
Message 5 of 8
RobDraw
In the old days, drawings were set-up to use a .ctb to assign lineweights and this has been the standard for a lot of places for many years. check the plot dialog to see if a .ctb has been assigned to these files. That is most likely where the lineweight settings are stored.
Rob
Message 6 of 8
pendean
Community Legend
Community Legend
Are you sure they were still there in that file in the first place? LWEIGHT settings are saved inside each DWG file and they don't just disappear on their own.
Or... were line weights assigned with a plot style table?
Message 7 of 8
you were Right they were connected with a .ctb  thank you for everything
Message 8 of 8
thank you but I no longer have 2014 so I can't really see the file from when it was that plus I found out that are linked to a ctb. file  thank you once again for everything
