Does it need to be a Script per se? An AutoLisp routine could do that easily. [In case that's what you mean, be aware that "Script" has a specific and different meaning in AutoCAD.] I'm not sure about a Script, but possibly.
Append the same specified text to all Layer names, or only some? If only some, how would they be selected?
For the color part, in command-line usage an asterisk will get you all Layer names, to apply the same color to in one color option. IN Script format:
_.-Layer
_color
YourDesiredColor
with an additional blank line [second Enter after the asterisk] to complete the Layer command. The same can be done in command-macro format to put into a menu button somewhere, or AutoLisp format, depending on what you really need.
so we have several packages that go out. the name is always changing. the client requires us to make sure we append the correct package name to all new scope layers (Will be wblocked out into a new drawing) then select all and append the required info, then all those layers need to be changed to magenta.
Something like should get you started:
(defun C:WHATEVER ()
(foreach layer '("Layer1" "Layer2" "LayerA" "LayerB" "LayerWho" "LayerWhat")
(command
"_.layer" "_color" 6 layer ""
"_.rename" "_layer" layer (strcat layer "YourPackageName")
); command
); foreach
); defun
