Layer Control Drop-Down Issue
jledgewood409
jledgewood409
in my layer control drop-down the layers do not seem to be organized alphabetically as they typically do. in the layer manager they are alphabetical. how do I get this back?
Patchy
maybe MAXSORT (Maybe)
jledgewood409
I typed MAXSORT and it gives me a default value of <1000>. what should I change it too?
Patchy
nrz13
From the AutoCAD help file:
MAXSORT (System Variable)
Sets the maximum number of items such as file names, layer names, and block names that are sorted alphabetically in dialog boxes, drop-down lists, and palettes.
Type:    Integer
Saved in:    Registry
Initial value:    1000
If the total number of items, also called named objects, exceeds this value, no items are sorted.
The value of MAXSORT is an integer between 0 and 32767.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
