Lasso select problem since 2019.1.2 update
anagnoMXUCG
anagnoMXUCG
Community Visitor
Community Visitor
I just did the above update and now the lasso select function is jerky and does not select.
I googled and it said to install 2019.2.1 to resolve the problem, but that is what caused the problem!
Everything was working very well before the update.
Thank you
natasha.l
Hello @anagnoMXUCG
I will test this for you right now & let you know how it goes, but in the meantime...please read the information provided.
I have copied the release notes for this update below, the differences are highlighted in blue.
What option did you use to install the update #1 or #2?
Release Notes |Installation Instructions
"You must have administrative privileges on your Microsoft® Windows® operating system to complete the installation process. Note that the Microsoft .NET Framework 4.6 for Windows (or a higher version) must be installed prior to applying this Hotfix.
Option 1: Preferred
Install the Hotfix for your product using the Autodesk Desktop App.
Note: The Hotfix installer will automatically install all previously released Updates and service packs on your computer.
Option 2:
Note: You will need to install all available Updates and service packs for your selected release version (2017, 2018, or 2019) prior to applying this Hotfix.
Download the correct Hotfix for your application from the Accounts portal to a location on your local computer (the AutoCAD Hotfix can be applied to AutoCAD-based vertical products and specialized toolsets)."
________________________________________________________________________
The AutoCAD 2019.1.2  needs to have been installed at some point  this update includes all the updates previously released for AutoCAD 2019.
Then, the AutoCAD 2019.1.2 Combo Security Hotfix should be installed.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
natasha.l
Hello @anagnoMXUCG
I just finished testing this, I used Option #1 & updated using the Autodesk Desktop app it automatically applied both the AutoCAD 2019.1.2 Update & AutoCAD 2019.1.2 Combo Security Hotfix.
The update did not cause any issues with the Lasso select tool, I have created a video here.
To Resolve the issue: Review all the information provided above. Try uninstalling the update, then try applying the updates using the Autodesk Desktop app.
natasha.l
Hello @anagnoMXUCG
Did you get a chance to figure this out?
