I'm a novice user but I would to figure out how to plot with a "universal" Title Block. Not sure I'll use all the correct terminology but I will try to explain the best I can what I would like to do.
I have a large drawing of a youth sports complex. Say it has 4 fields I would like to print each individual field with the same or common title block. If possible I would like to just use the "window" function to choose which field I would like to print at that time. I have a generic title block now sized for the 11 x 17 I would like to print saved as both a dwg and a template. Not sure if I am heading in the right direction or not.
Thanks!!!
The manufacturer recommends creating layouts, creating a viewport in each of them and using Publish.
But if you have all the title blocks only in the model, and you can not transfer them to the sheet space. Then you can use the add-ons for printing.
Look for a Lisp or VBA forum.
For example, you can use this:
There will be questions - write.
