Hi please see selected Polylines, My Hidden lines is scaled at 1 (default) but it doesn't scale even if i change its scaletype. It only changes if the scale is 0.02 but it is too small. bigger scale than 0.02 results to this too much spacing on lines. please help. thank you.
Solved by paullimapa. Go to Solution.
Post your file please.
You can delete all unaffected objects beforehand.
And let us know which AutoCAD version you use (post the ABOUT window).
Jürgen Palme
After opening your file (in ACAD 2025) I see this:
For me it seems to look well. What do you expect instead.
[EDIT:]
... and also tested in ACAD 2022 1.4 - same result. Her I can not see problems.
Jürgen Palme
As you can see in below attached image .. it's normal . Ltscale=1
I open it and find it as seen below.
Imad Habash
@oliverlarracas wrote:Hi please see selected Polylines, My Hidden lines is scaled at 1 (default) but it doesn't scale even if i change its scaletype. It only changes if the scale is 0.02 but it is too small. bigger scale than 0.02 results to this too much spacing on lines. please help. thank you.
Its a block.
Fix it in the Block Editor (double click the block, then close block editor) change layer and its properties:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Hi. i think the problem is the settings or laptop error? I tried opening another blank drawing and made a line, it is fine but after changing the line into a dashed line, it disappeared again or like, became bigger spacing. I also tried opening old drawings and its the same. dashed lines are big.
or laptoperror?
Yep. Mybe you have a mix of metric and imperial linetypes. See also the help for MEASUREMENT system variable.
I think the MATCHPROP command will be the easiest and quickest way to repair the wrong "scaled" object properties.
Jürgen Palme
Could be a compatibility issue with your graphics driver. Set GfxDx12 to 0 and restart AutoCAD. Still not fixed then enter GraphicsConfig and change 2d Display settings to another option. If still no change in GraphicsConfig disable Hardware acceleration. Also you can try updating your graphics driver in Windows OS
Hi, thank you this has fixed the problem. Can i get an elaborative explanation why this has occurred to the drawings though i didnt even set it to 1. Also i am just using a low graphic computer, with a dual core. Though thank you for the help.
Hi it has been fixed, by the paul li reply, (I am attaching the picture of reply, cause i dont know how to attach a reply). Thank you for bearing with me.
Well, with each AutoCAD release the graphics requirements changes. So graphics drivers that may have no issues with a prior release may suddenly experience problems similar to what you've experienced when a newer version is installed. This is why Autodesk provided an option to forego the newer version graphics enhancements by having the GFXDX12 disable it for backwards graphics driver support. You can read up more on this topic here:
How to use a previous DirectX version in AutoCAD Products (autodesk.com)
