Language changes
Language changes
Language changes
 Hello, I have a problem with my program: I use the spanish language version and some changes have ocurred. When I open the layer properties manager all words are translated to english (linetype, freeze, lineweight, new layer, transparency, plot style,...). But it is not the only thing... Autocad also doesn't recognize some commands in spanish -suddenly, they are unknown- so i have to type in english.
 I add some pictures... For example typping the command ''EXTRACDAT'' (in english ''DATAEXTRACTION''). Main menu is in spanish and, as you can see, the layer properties in english.
 Maybe the solution will be uninstall and install again, but I hope you can help me... Thank you.
Darin.Green
Reset your application settings to default:
Go to Start > All Programs > Autodesk > AutoCAD 2016 > Reset Settings to default
If this information was helpful, please consider using the Accept Solution
