lagging when using LINE or PLINE command
hi.. when im using LINE/PLINE my mouse cursor start lagging badly, it jumps from spot to spot and not running smooth as usual.. any advise?
imadHabash
Press F9 to turn OFF snapmode , any changes ?
Imad Habash
Alfred.NESWADBA
Just for the first point and then it works ok ... then you should turn off UCSDETECT (dynamic ucs)
If it's for all points, so try to play with object snap (<F3>) and 3D object snap (<F4>).
Your video can not be viewed as it is marked as private. So we can only guess...
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
hi.. thanks for the help' i made the video public. tried to change the
UCSDETECT action and play with th object snap but nothing helps.. the only
thing that helped me is to change the view mode from wireframe 2d to a
different on but then the display is much less comfortable.
turnning snapon tool off did not help, as for now the only thing that helps is to change to viewmode from WIREFRAME2D to a diffrent one, it helped me with th line problem but now the screen display is diffrent and less compfotable.
Alfred.NESWADBA
does this happen with a new drawing based on an original AutoCAD template too, just new file, one line and then ... again lag?
Can you also please start command _ABOUT and show us a screenshot from this dialog, same please for command _GRAPHICSCONFIG.
- alfred -
Alfred NESWADBA
