Label Style not including User Defined Information
aserletic
aserletic
I have created a point file format to include Offset information, under a user-defined column.  When I include the user-defined information into a custom label style, the information does not show.  I have attached a screenshot of the settings I have, but from what I can tell I have done everything I can to get it to show.  Any help would be greatly appreciated.
rkmcswain
Your screenshots are from Civil 3D, but you posted this in the AutoCAD forum.  Not as wide of a C3D audience over here.
R.K. McSwain     | CADpanacea | on twitter
aserletic
I'll repost, sorry.  I didn't see where the C3d forum was.  Thank you
rkmcswain
No worries - just wanted to let you know.
Civil 3D forums are here: https://forums.autodesk.com/t5/civil-3d/ct-p/4003
sambremer
Not sure how much this will help but I would just create a new label as a Station Offset format from an Alignment feature and just ultimately select your point. Make sure to select the arrow that I circled in red so you properly add it to your text content. I would customize it so you add Point Name, Station, Offset.
aserletic
This is something I have thought about, but I need elevation included in the point label and alignment labels don't allow for elevation to be used 😕
sambremer
What you want to do then is add a reference text and I would either try the Cogo Point or Surface option and see what works for you. You should be able to get all of the information you need.
