AutoCAD Design Training Courses You and Your Team Need Right Now!
harold.roxxx
Message 1 of 1
harold.roxxx
Gone are the days where every bit of design must be thoroughly done by hand. Today, the whole process of designing has been automated so that the process is quick, accurate and cost-efficient. Design in general can pertain to any field, be it architecture or automobiles. AutoCAD is the most trustworthy design software available to the industry today. A product of the Autodesk software company, it’s increasingly used by top automobile and construction firms. Naturally, these companies are constantly on the lookout for professionals who can confidently operate AutoCAD and are well-versed with its diverse features. This makes AutoCAD training a recommended prerequisite.
What is AutoCAD?
It is logical to question the usability of a software. AutoCAD is computer-aided design software that helps in visualizing, creating, and editing product designs, while using simulations to predict how the product would work in the real world. It is a huge advantage when the design team knows how to make use of all the features of AutoCAD.
The benefits of this software are abundant-
  1. It improves accuracy and reduces errors- Creating designs by hand can be inaccurate to an extent and can also result in significant errors. By automating the design process, errors can be reduced and precision can be improved. This means the final design can be reached more quickly by making simple modifications.
  2. Cost-effective- While the software itself has up-front investment and installation costs, the company can receive a return and increase cost savings in the long run. This is possible as AutoCAD reduces the cost of making modifications and alterations, and speeds up the development stage. Because of this, the product can be introduced more quickly than if traditional methods were used.
  1. Saves time- Research and development time can be reduced significantly, giving the business ample time to focus on other important factors such as marketing and sales. The company can then afford to increase innovation since the R&D of the product life cycle is smaller.
  1. Technical benefits- The technical benefits of employing AutoCAD are extensive. AutoCAD helps in the creation of a manufacturing database to house data regarding the  dimensions, component drawings, and model’s shape and specifications. It also has a layering feature that helps in visualizing a complex model by isolating individual parts and components of the whole model. AutoCAD is programmed to carry out calculations such as volume, area, the center of gravity and more. Precision is especially important for construction and automobile designs. Furthermore, the software can also transfer, import, and export data easily so that the design can be moved across platforms or sent to other team members.
AutoCAD is an extremely productive software with multiple benefits. However, to master all these skills, it is necessary to take AutoCAD training courses. This not only provides certification but also increases credibility in the market. The certification acts as proof of an individual’s AutoCAD knowledge and expertise. Autodesk, the producer of AutoCAD software, provides several courses that give a 360 view of the software.
Applications of AutoCAD -
AutoCAD is used across various industries, it is a prerequisite skill for many potential jobs. In fact, some sectors will have it as part of the potential job title, e.g., ‘AutoCAD Electrical Drafter.’ Although there are many AutoCAD career options out there, they are primarily prevalent in the following industries:
  • Drafting
  • Engineering
  • Architecture
  • Design
AutoCAD has become a necessity in various sectors as it enables users to draft designs that can be reworked and modified. It allows for wiggle room when testing prototypes and working on improvements for efficient functionality.  In the engineering field, it enables drafters to create detailed electrical plans and even estimate material costs.
Certifications and Benefits for an Organization:
AutoCAD is widely used by several professionals and firms for various applications. The software is most commonly used for designing and drafting. The advantages that it lends to an organization by upskilling its employees are multifold -
  1. Increases productivity of the design team – The organization’s design squad will be able to better visualize the final product with the help of AutoCAD. Adding animation will also give context into seeing how the product will work, thus showing where modifications will be needed.
  2. Improve the quality of design – The software offers many tools to help carry out a thorough analysis of the proposed design. Better designs will allow for the execution of manufacturing more quickly, and reduce wastages that occur with faulty designs.
  3. Better communication – AutoCAD software drawings are easy to understand and follow a standardized format. It also helps documentation in that there are fewer drawing errors and greater legibility.
  4. Create a database – By using AutoCAD software, the design templates and workflows can be saved and used for future references. This increases efficiency and reduces time spent on new designs.
The most popular AutoCAD course currently is the Autodesk Certified Professional in AutoCAD for Design and DraftingThe course is curated for those who have advanced skills and can solve complex challenges in workflow and design. The certification takes the user through each feature of the AutoCAD software; it covers sections on drawing, organizing objects, advanced editing features, layouts, drawing with accuracy, drawing management and more.
Those who have completed a course at this level employ a comprehensive skill set that provides an opportunity for them to stand apart in a competitive environment. This also aids the design team in providing better designs which produce a cohesive final product for the organization. The Autodesk Certified Professional: AutoCAD for Design and Drafting exam is the recognized standard for measuring skills and knowledge in AutoCAD.
With this course, the following skills are gained:
  • Draw accurately with the user coordinate system; draw and organize objects and use advanced editing functions.
  • Create and manage layouts, outputs, printings, and use annotation techniques like markup tools, hatch and fill, multileader, and dimensioning.
  • Perform drawing management techniques, use blocks for efficiency, and control external reference and underlay files.
  • Demonstrate the skills and knowledge required for taking the Autodesk Certified Professional: AutoCAD for Design and Drafting exam.
Replies (0)
