- Mute
- Permalink
- Report
I'm attempting to use the sheet set manager as a tool for dragging and dropping standard details into a drawing. As a standard, we typically don't use sheet sets for anything. I've created a new sheet set, defining the "label blocks for views" as the .dwg wblock that is our standard drawing label, but when I insert a model view, it doesn't come with a title block at all.
I then created an example sheet set where the "label blocks for views" definition is pre-defined using a default title block. Upon dragging and dropping a model view into the drawing, the same thing happened... Not sure at all why this is happening. Scale maybe? Any help will be much appreciated. Thanks!
