AutoCAD Forum
KMZ AND PDF FILES
1 REPLY 1
507 Views, 1 Reply
KMZ AND PDF FILES
Hello, i am currently working to try and find a solution for printing prints to scale. I usually recieve PDF files with blueprints that are easy to print on the plotter because they are already set to scale. On the other hand sometimes i recieve pdfs that are not to scale, and my employer wants me to print them to scale. Can i import the PDF into autocad to print to scale? Also sometimes i recieve google earth files with drawings, and i was told that those could be imported into autocad so i could print them to scale? If anyone could help, i am new to autocad and would like to know. Thank you!
1 REPLY 1
pendean
You can't truly fix a PDF that is not to scale: you need to ask the PDF file creator to fix it at the source.
All you can do is import the PDF into AutoCAD and do your best at sizing it: it will remain flawed though.
AutoCAD Inside the Factory
