JWW format is not availble in AutoCAD
kylekiller1988QV37T
kylekiller1988QV37T
I received a drawing from my friend who is the engineer from Japan, but I cannot open this drawing by AutoCAD.
So, is it any way to import or open the file?
imadHabash
It's NOT applicable for AutoCAD ... a JWW file is a CAD drawing file format used by the JW_CAD software, which is popular in Japan. While it's the native format for JW_CAD, the extension can also refer to a Java Web-Workflows Data format from different software. You need the correct software, either JW_CAD or compatible programs like ZWCAD or RootPro CAD, to open and work with the file. >> Click <<
Imad Habash
Moshe-A
@kylekiller1988QV37T  hi,
Or you could ask your friend to convert it to dwg for you 😀
paullimapa
Could you ask your friend in Japan to provide you with a dxf file?
Paul Li
IT Specialist
@The Office
engrjvb
Encountered this before, we downloaded the JWCAD for us to open it.
If I remember correctly, there is a DXF option to export or save it which can then be imported or opened in AutoCAD.
Automation is to your time as compound interest is to your money
