How can you use a JPG file with an AutoCAD drawing? Is it possible to convert a raster JPG image into a vector based AutoCAD file?
Solved by john.vellek. Go to Solution.
There are some useful ways to incorporate JPG files into your AutoCAD drawings
Is it possible to convert the JPG into a drawing file?
Native AutoCAD cannot convert a jpg image to vector based geometry on its own. There are applications though, such as Autodesk Raster Design that can make the process easier. It helps to stretch and warp an image to real, known dimensions and then helps to essentially trace the image into vectors. NOTE: Accuracy is always a concern as pixels are a fixed size and do not stretch or correlate to real world dimensions the way vector geometry does so there are inherent flaws in the process.
